Audiopipe 3000d
you can but it will put the amp at a 1ohm load which the amp my take if you have good electrical backing it.
ive seen the ap3k burped at .5 a few times and it did ok, but im not sure about it playing music at 1
after further review, it is a 2 chan. but what i said above still applies.
your either going to be getting around 750 to each sub or pushing the amp past what it is designed to do. which may be possible
The reason I questioned it was because I'm going to have 1 18 and hook it up to a 3000d amp then I'm gonna get another 18 and run it at 4ohms for alitte until I get another 3000d amp
ok thanks, my team mate is looking for an amp that will take 18V from the alts he was going with some AQ 3500's but they are out.
if he has a regulator and can turn it down to like 17v i would do that. 18v may be fine for just comps but i sure as hell wouldnt run it at that for a daily
playyamxz550
playyamxz550
Memphis
pr-festiva
NorthFramingham
    Jun 30, 2026
