Xprime4
****in' canadian
Hi everyone
Just got my epic-160 unit, thanks to kamania from here. While i was waiting for it, i did a lot of search and didn't found enough infos so i'm putting a small review on the unit.
Here's the specs and infos on the epic-160
http://www.audiocontrol.com/t34/5250/14152/In--Dash-Car-Audio-Processors/EPIC--160-In--dash-Car-Audio-Bass-Processor-and-160-dB-SPL-Display.html
So it's a 1/2 din in dash unit. It need a full range signal to works properly, so it got to be put before any crossover/equalizer. I'm also using a clarion 7band eq, 1/2 din too with subwoofer output control... a must if you use the epic-160.
As an added bonus, there's a db meter and a voltmeter... i'll be back on this latter on.
It does what it is suppose to, in a very impressive way imo. All the review i read were talking about how "un-natural" the added bass was or on how it's almost like an line driver, which ain't true at all. If used correctly, it an hella fun toy.... LOT OF FUN //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
There's three important knobs on it.
1) Para-bass frequency center knob: 27hz-63hz
2) Bandwidth knob. Letting you choose on wide the restoration will be. from 30-250hz
3)Restoration level knob. How much added signal in the output
Some reviewers were saying that most of "already bass loaded" songs just sounded bad with it. There's a "restoration" button available, so in just a finger push, you can bypass the unit. Really cool
I did some test with songs with very little bass content like bryan adams and some local rock bands. Playing with the parabass center and Bandwidth know on each song really bring out some awesome clarity bass line that look really natural to me. You don't need to push anything and it sound cleaner than pushing the amp gain and trying to get bass were there is none. So far, i really love putting the parabass center at 27hz with a 30hz-50hz Bandwidth range. It put some lows... i mean LOWSSS!!!! bassline in every existant songs. I need to lower subwoofer output a LOT each time I use the restoration system
I tried it with rap songs too. On jeezy songs, the bass would sound "akward" sometime, but when you play with the control, you can definitively get something different. You don't like a bassline in a song, just modify it to your taste. I was surprise about how good i could make any songs sound. I tried with already low end bass songs like white girl and it does works too... just be easy on the restoration and look at the woofer wanging like no tommorow //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I tried it on songs with higher bass frequency like "whatever you like" from T.I. I always hate how the bass was blending in that song. Content looks to be in the high 60s-70s and just didn,t sound great in all the systems i heard. Now it does.
With some tuning, i could get it to sound like a jeezy song with intense, low40s bassline. Now sound 100x better. Seriously my jaw dropped. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I'll try it with some Celine Dion songs (she's Quebec's proudness) latter on. I'll def play with it a lot in the coming days.
Now on the look
The illumination on the unit is green, but very light compared to my headunit and eq. It does fit with my clock color though. On bright sunny day, i can't see what the db meter/voltmeter says, until i put my hand just over the screen. It ain't cool, but not too annoying too. At night/cloudy day, it is a lot easier to read.
The Voltmeter. It is more accurate than my 20$ shipped from hong-kong voltmeter i have near the dash too. This one seems to be .2-.3 under the real reading at front batt car on/off. Not too bad. When i start the car, it says 14.2 while at the front i'm at 14.4-14.5
The Db meter
I don't know how accurated it is, but i hope it's not that much. I scored 142 on music ( lost -guorilla zoe ) with my sig setup, which would be a nice deception. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I won't take it too seriously, but the kamania, the ex-owner, says it was 1db under the tl. Still 143 ain't satisfying with two 15s and around 1800 +/- watts of power. It is really consistent and always give me the same score, with the same songs.
There's a peak holding button too. I register the higher score and keep it on screen till you reset it. The score always seems to appear half a second after the bass hit... not too bad. The mic seems to pick up only the bass, so i won't be able to tune my mids/high with it. It doesn't seems accurate at all under 120db though, as it's going from 65-94 db without any sound (car off in parking windows shut) Over that, each +1 volume increment on my headunit seems to bring few dbs more in a realistic way.
now on the bad side
Adding a lot of content in the lowend region also affect my mids a lot. Right now, the hpf set around 80-90 hz with a 18db sloppe. I'm sending a lot of power to the crossover too. It does boost them nicely at low level, but once you start pushing the mids at high level, you better keep the bass restoration at real low level. They pick up too much bass, even if I set everything at the lowest point. A better sloppe would probably help a lot.
so that's my epic-160 review, thanks for reading. Any question just ask. Sorry about all the gramathical error and the sentence structure. I'm a canadian frog //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
have a nice day and consider this audiocontrol unit if you love bass. I can't believe i didn't get one before. It is the ultimate bass toy. Just be carefull coz it could cook your subs pretty quick if you aren't using it properly
Now on the look
The Db meter
now on the bad side
