Audiobahn with L7's
  • 1
DSGB08
10
Atlanta
Would an Audibahn A2200HCX amp work well with 2 Kicker L7 15's which run @ 2 ohm. The website says the kicker 2 ohm L7's will run at 1 or 4 ohms. The amp runs at 600x2 @ 1 ohm, 1600x1 @ 1 ohm RMS. Do you think the L7's would work well together with this amp??? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
DSGBO8-(-YOU WILL NEED THE DUAL
4 OHM VOICE COIL L7 SUBS)
wire each sub in to a 2 ohm load
then wire both subs in parallel for
a 1 ohm load to your amp.
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
DSGB08
DSGB08
Atlanta
DSGB08
    Jun 1, 2024
    May 31, 2024
