audio gurus pls help
coolrolla
hi guys,
i have a simple question....... how can i center the sounds on my car.....i want better stage height (at least below the rear view mirror) .....my weapons are....
-6.5" boston rally seps in front ..the tweeters are located on the side of the floor ala kick panel....
-alpine HU 7525 (old school)
-6.5 " kicker coaxial rearfill
-2 12" kicker subs (125rms) in a sealed box....
-RF punch 60 for the seps
-fenton acoustics for the subs (125rms x 4)
-pyle 3 way x over...
i'm on SQ ..... any help would be appreciated tnx......
For stage height from kick panels, get yourself an EQ. If you want a simple solution that may cause troubles for imaging, just raise the tweets to the A-pillar. The draw from the coax's in the back may also be a detriment to the stage height. Experiment by fadding front and tweaking.
ah i see.....the coax at my back might be the cause.....i'll try to fade it out with my xover and see what will happen.....
do i realy need to get an equalizer? what will help....a graphic or parametric equa?
coolrolla
coolrolla
manila
Mark_ab
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
