ATTN: Digital Multimeter Users
Lol. aight you win ^^
What exactly am i looking for on the h/u to fix my problem.. the amp readings? or something else?
like 40-50 volts somewhere between there
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
He said to buy a aftermarket h/u and that would fix my low voltage problem. I was trying to ask what exactly am i looking for in the headunit if i were to puchase one ex: Peak Output, RMS Output, etc.
i'd say the converter is bad or the ground burned inside.
You think the converter is bad? so possibly switching it out would fix my low voltage problem?
There is one wire that is hanging by the converter not plugged into anything but i'm not sure its meant to be like that
I dunno about if RMS output of a head-unit is true (look for CEA-2006 compliancy) on it, also, I'd find a head-unit with at least 4v pre-outs. Would you be adding an amp onto the external speakers also? Look for a head-unit with 3 pre-outs (front, rear, and subwoofer).
Hope this helps. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Does your LOC have a gain control?
Well the higher pre-out voltage the lower you will have to run the gain on the amplifier. I would look for a min 2 volt but some prefer 4 volts pre-outs. My current deck is 2 volt.
just get something in the range of 2-4v preouts. they will suffice for everything you need really. just go with a quality name and you should be set. if you're going to want to run a speaker amp in the future, look for an HU that has 1 set of subwoofer preouts as well as 1-2 sets of speaker preouts.
I reached the voltage i was looking for!
I don't know why, or if this even makes sense but...
I turned the Bass on my h/u from -6 to 0 and whaa laa instant boost in voltage //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
now i have plenty of power i got 34.5 volts from a 50hz tone volume set at 23/40
appreciate all the help tho
Kastlez_
Kastlez_
Bay Area, CA
Kastlez_
