Attn. All Box builders and Wisconsin Members
Hintzyboy
Sparks mean its working!
Hi all,
First off, I need some box plans drawn up with cut sheet dimensions. Max exterior dimensions are 13" high, 5" Top Depth-11" Bottom Depth. I have 52" of outer length available, but that needs to include some clearance between the port and the cab wall (side-firing port) What is the most airspace I can get out of these dimensions if I want to tune to 30-35 hz? Box is being built for a Team-PSI built TC9, and I'd like to get around 25 sq.in. or port area. I will also be using 1/2" MDF for the back and bottom plates to give some extra clearance for the sub magnet.
Second, I'll be starting a new build soon, and could use some help. If any Wisconsin members within a couple of hours of Wiscosnin Dells are interested, there will be plenty of free food, etc.
If anyone is interested in either proposition, hit me up on this thread, through a PM, e-mail, or MSN messenger.
e-mail and messenger address: hintzyboy@hotmail.com
Thanks,
Aaron
I'd be glad to make you a design, but I won't be able to drive to wisconsin to help with the build. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
PM me if you're interested in a design.
is this for a regular cab s10?
with those dimensions you can get about 2ft^3 internal volume before port and sub displacement.
i just designed one for my buddie's s10, and i managed to get 1.85ft^3 tuned to 35Hz with 21in^2 of port.
he had to make a notch for the center console, and lost a click, though.
he's thinking about buying some 8's to get his leg room back.
(hope he doesn't mind me linking):
http://www.s10forum.com/forum/showthread.php?t=288934
yup, reg. cab. No center console, just one sliding bench seat. The seat is already moved up as far as I will allow. I'm not willing to give up the comfort and safety just for a little extra sound.
If it helps. I can go up to the window like the box pictured in the s10forum thread, but I'd have to have a couple inch indent on the passenger side so I can mount my amps.
I'd rather have the amps on top of the box though, so I can hide the wires easier.
Just an idea, what Airspace and tuning would this box get me?
Outer Dims:
48" L
13" H
5" Top Depth
11" Bottom Depth
4x6" Square-O port
-1/2" MDF used for Back plate, Bottom Plate, and port sides. 3/4" MDF for the rest.
Outer Dims:
48" L
13" H
5" Top Depth
11" Bottom Depth
4x6" Square-O port
if you went with those dimensions you get 2ft^3 net internal.
for his i did a 3"x7" port 21" long to get to 1.85ft^3 @ 35Hz
if you go with a bigger port and want to tune that low your net volume will be lower.
Hintzyboy
Hintzyboy
Baraboo, WI
xluben
