At witts end with speaker buzz!! HELP!
  • 4
hermgreen03
So i have literally replaced my rca's, went from cca to ofc power and ground wires. I have cleaned and checked all my grounds. I have done the big 3 and rerouted all my wires...power wires away from signal wires. The noise is not alternator or engine related. When I unplug my rca's that run my.subwoofer the noise goes away. As soon as they get plugged in, the noise comes back through too my front speakers. I can't hear the noise at half volume and wven with my sub gain turned all the way down you hear it. What could this be. Im using a 4 channel amp, 2 front channels for components and channels 3 and 4 bridged for my sub. Im too the point of buying a separate monoblock for my sub and seeing if the noise goes away. Im lost here please help
What would cause a amp to do this? Its done it since dayb1. I just did a lot of.research and tried to figure it out myself....needless to say that didn't work lol
I have one last thing to do before I can get a exchange. Apparently this amp needs a mono signal when its bridged. I believe its on 4 channel right now. I have to switch it to two channel.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
  • Locked
If you’re going to spend that kind of money, you should be looking at Beryllium domes too. Like the ScanSpeak Illuminator D3004/6040-00 Beryllium...
Have you had the chance to make a comparison of sound quality and performance between Audiofrog GB15 tweeters and other brands like Morel Supremo...
In grade school we discovered some learning issues and by the following semester she was invited to join an advanced math program. Did robotics in...
  • Locked
I have some nice high end 6x9s if your still looking
hermgreen03
hermgreen03
stanley va
hermgreen03
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
