It doesnt matter at this point, the alarm would still acknowledge the remote start signal if anti theft is enabled. Your car just wouldn't start. Re-read my previous post and go from there.ok i will look there for it. is that the drivers or passanger door?
Does that unit use a ribbon cable to connect the relay pack? or is it all internal? I'm too lazy to go look //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifok so i went out tried regrounding the neutral safety wire and then tried to start it nothing, then i tried to do it with the activation input and got nothing, tried redoing the hood pin got nothing, no i am starting to think that my brain could be bad. i even unpluged the brain and then the remote gave me the error beeps. anyway to check for a bad brain?
I work monday, thursday, friday, saturday usually... but I work at the Saginaw location. Make sure the ribbon cable is plugged in all the way on both ends... and check them with a multimeter. I've saw a few times it looks like they are plugged in all the way... but they aren't... and that causes the almost exact same symptom you're talking about.haha yeah it uses the ribbon cable and that is plugged in all the way. beleive me i have made sure a few times. but shyne what days do you work at dukes? how much would they charge me to have you look at it and figure it out? i am in lansing and flint is like 45min from me.
Tapping the activations input twice to ground will do the same thing as hitting the remote start on the remote... he tried that and it didn't work.before deciding its a faulty brain, try manually programming the remote start button on your pager for the remote start function on the alarm. if u dont have the instructions how to then let me know and ill link them
