Assassin Ported Box Complications
  • 5
Woodmister
Radford!
1,210
NorthVA
So I have a 10" AA Assassin.
AA says use 1.2cubes tuned to 32Hz
I have ran three 'calculators/programs' trying to figure out the correct size of the box/port/port area and the RE one seems to differer from the other two the most.
Help would be much appreciated
I need to keep the external hight (12") and external width (33") the same, with the depth being variable.
WIN ISD
Subwoofertools.com http://www.subwoofertools.com/forum/ported-box.asp
REAudio http://reaudio.com/speaker_box/LPort_Box_Calc.html
I wouldn't trust that calculator. I have found it to be way off from time to time. It also is spot on at times. Its just not constant. Here is an example...
http://forum.realmofexcursion.com/showthread.php?t=23030
In the thread a person used it to get a 2.2@32Hz
He had 42"^2 of port with a port length of 44.75"
I did a similar design a while back and it looked like this...
As you can see the port area is the same and the volume is very close but, the port length isn't even close. Not by a long shot!
Also if you take the info giving my the online calculator and add it all up, its doesn't match. I explained everything the best I could in the thread.
I just don't trust online calculators. That my, I like to do it with pen, paper and a calculator. That why I know its right.
Jon
Well I only ask cause the WinISD calculation kinda matches the sites calculations/box plans.
Its kinda hard to mistrust WinISD right?
PS, just checked it with http://www.carstereo.com/help/Articles.cfm?id=31
For:
1.2 cubes 32hz
Port Height: 10.5"
Port width: 2"
It gives me a length of 41.27"
So now we have 3 sources that say ~40" of length for the same dimensions.
I checked the volume of the box, and its pretty darn close...
One question, What is the gross volume of the enclosure??? I just did a design with 1.2 as gross (wasn't paying attention) and got a final port length of 41.2" for the same info given. This is not correct b/c I didn't have the right gross volume.
I didn't say its always wrong but it is inconsistent. For some enclosures its spot on but, others its not even close..
Jon
To use in this cubby before it starts to decrease in hight. It goes from 12" in the center (under the material) to 11 at about 2" on each side
For yours. Was going to send you the link, but GF got on the PC and closed the window out. Just trying doing a narrower box, changing xmax to get the right port size, and you should be able to get an "L" port.
Well I dropped the xmax to 15mm (instead of 15.5) and got an L port.
But it decreased the port area to ~18.75 sq in (1.75x10.5)
From 21sq in (2"x10.5")
WinISD didnt show a change in the vent mach (.04) from the two different port sizes, just saved me ~5" of port length with the smaller port...
What is an acceptable port area for a 10"?
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
I want to try my hand at a ported box for one IDQ12. I built a sealed box a few years ago and it sounds good but I want to see how ported...
Woodmister
Radford!
Woodmister
NorthVA
Woodmister
