AS1 box and scores to eventually come
What kind of fuse setup are you going to run? Being limited to 50 amps worth of fusing makes things fun. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Fusing is going to be the toughest part:( I shouldn't have too much trouble getting it loud :knock on wood:
Here's the result: 145.8 @ 40hz @ the headrest. I found this weird because my last box peaked around 50-51 hz. I put in/took out corners to see how it would change my score and it pretty much did nothing. I wanted to get my note up but neither corners nor changes in tuning would do it. I also managed to pop my 300a fuse lol.
You want a lower note for the headrest. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And popping a 300 amp anl=bad. Though the stock 300 amp ANL that comes with the zx2500 is weak compared to others (even the separate 300 amp kicker ANL's that you can purchase individually)
I wasn't expecting to drop 10hz:confused: I may have to do a slightly smaller box to get my note up a bit. Yeah it was the Kicker ANL fuse. I was pretty shocked that I popped it because that fuse has seen a ton of burps back to back.
It's very possible to drop that much. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and it sucks //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Lakota
Doesn't Know $hit
Lakota
Louisville, KY
tommyk90
