as if the mini cooper wasn't enough...
thats what i thought, 1/4" inside the bottom lip thing on the panel, then 3/4" for the rings/flush mount?
is the back sealed? thats one thing i wanna do is have a sealed pod.
That is correct sir. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif It's not sealed, although I wish it was. It's kinda hard since the window regulator is right there. You might be able to work something out though.
where should i put the tweets at?
I had mine in another little pod just above those, but the placement wasn't the best. I would consider maybe in the pillar or the stock dash speaker location. I think that would be the best. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
i might add a second 3/4" baffle like you did, so my mids will stick out a little more than on your door, that way i dont have to cut into the stock door and i can leave the back sealed up
orangecounty1
orangecounty1
Tampa, FL
orangecounty1
