Simple question, the RCA's that came in my wiring kit have to ground wires connected into them. I did not see this on any of the other ones in the stores.
As soon as you plug your rca cables into your headunit they will be grounded. The rca shield ground(the outermost part of the rca plug) is connected to chassis ground in the head unit(usually through a very small fuse inside the headunit). If you had any noise for whatever reason you could try hooking up those ground wires but it isn't usually necessary. This is the wrong section for this kind of question. People on this forum usually frown on people who post in the wrong areas.
