are test tones quiet?
so disconnect my wires for the subs at the amp? so the amps terminals will be empty?
and if so how does that actually work then? if there is nothing pulling current from the amp?
Unhook them (or the +) to set gains using a dmm. If you're doing it by ear leave the subs hooked up.
nothing needs to pull current the amp puts out AC voltage and thats what you read with the dmm
ok so if i did it right. i take my rms or wattage desired and find the square root of that and that is what i should be looking at ac voltage wise ? so 1500 watts at 1 ohm is about 38.70 volts so i should set the gain to reach that voltage with all my head unit settings to lowest? sub level, sla, loudness, bass, set it to the voltage and then i can adjust the settings on my head unit?
yes 38.7v and yes have evrything flat or off. also you sure your amp does 1500 clean? what amp?
im guess it does 1500 watts clean. its a crappy hifi amp 3000 d but i know its not putting out 3000 watts.
if there is a way to measure my wattage being produced i would love to know.
got a fund going for a better amp to push around 2000 rms
im guess it does 1500 watts clean. its a crappy hifi amp 3000 d but i know its not putting out 3000 watts. if there is a way to measure my wattage being produced i would love to know.
An RMS volt meter set to AC volts will give you a reading from the amplifier outputs. With some basic math you can calculate Volt Amps, or VA, but that alone is not enough to give you power, or watts. You also have to make assumptions about the current supply into the amplifier. It's not very accurate.
sounds_explicit
sounds_explicit
cleveland ohio
inferno1985
