are amp caps nessecary for the boost
  • 4
Caps are most beneficial to a system when your car's electrical system is functioning properly- meaning lights not dimming- etc.
If you do not have that issue - then go for it. Caps take some of the strain off of the electrical system allowing a more balanced current flow throughout the car. These are expecially usefull for subwoofer amplifiers as they demand the most current.
However, if your car is allready struggling for power, then a cap will do little good.
take it easy,
-zane
157
352
470
  • Locked
756
Amp
551
wickedmooch
wickedmooch
South Lyon, MI
MikeofTulsa
