ARC kar 1000.2T acting shady, HELP PLEASE!
  • 2
anarchy57
Maryland
I hooked up an Arc Kar 1000.2T to my 2 12" RE SE's and there's quite a bit of an issue.
There's 2 lights on the amp, one for "Power" and another for "1-Ohm mode" and these 2 lights blink simultaneously. I figured something was wrong with the wiring on the subs to the amp, but I was wrong. Even when the subs aren't wired to the amp, the amp still has those 2 blinking lights.
In the manual it never mentions anything about this.
Does anyone know what the problem could be?
I checked the ground and power cables and they seem to be fine..
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
  • Locked
COMPLETED Arc Audio Amps
Arc Audio Amps I am selling. KS300.2 - $200 OBO KS300.2 - $200 OBO KS300.4 (Not Pictured) - $250 OBO X2 2500.1 - $950 OBO Located in...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
anarchy57
anarchy57
Maryland
3.5Max6spd
