Arc Audio Instruction Manual fail
Nut Hair Trick
Pubes
Ok people, I was just looking at the instruction manual for my Arc amps I just bought and this thing has me f'd up in a way. The wiring diagram contradicts what actually should be done. For example, it has the GND input fused to the battery, and the +12V grounded to the vehichle. Now, my question is, which one is right? The labeling on the amplifier itself, or the wiring diagram? The amps are FD2200's
lulz. what do you think
Ya know thumper.... normally I would agree with this comment, but I just bought 2 ARC amps and now I'm interested to hear the response from Brad in Tech Support!! I got a FD4150 (same manual as OP has) and a FD600.1. The manual for the 600.1 matches what I would expect on the amp. The 4150 has the same issue as posted above. The strange part (to me) is that both amps use the same connector for power, but the grounds and +12 are reversed on the amps. I find this strange because, coming from a manufacturing background, I know that the cheapest and easiest way to build product is to change as little as possible. So why have the connecter go GND-TURN ON-12V on one amp and then 12V-TURN ON-GND on another??? I'm thinking someone got lazy and did a "copy/paste" somewhere here, but the question is, did they "copy/paste" wrong in the instruction manual, or the screen printing on the amp???? I'll either wait to see the response from Brad or pull off the bottom cover on the 4150 (PITA Arc!!!! Put the fuse external!!!!) and check with a DMM.......
Nut Hair Trick
Pubes
Nut Hair Trick
Arlington, Tn
Chrisw21
