arc audio amps???
There is a KS500.1 mini, KS500.1 standard size, XXD1500.
Better question is why are you comparing a 500@1 amp to a 1500@1 amp? Those CVR's wont handling those 1500.1's. And why an SQ Arc on shitty subs?
If they were recommending the KS1000.1, yes, strictly from and SQ stand point, I would take them over the zx1500's.
But, if SQ is what you are looking for....the CVX is not your sub of choice.
Zeff is a madman when it comes to amp design.
hes building my box, and he said those amps are g class, very efficient, and says the kicker amps **** and sound like ****, the subs are supposed to be 750rms, thats why i thought zx1500's would work
its been like 7 years since i built a new system, i thought kickers were good, my old solos lasted like 6 years till the blew and cost me a fortune back then
If you're going with four 12" CVX's you're obviously not going for a sq setup. Loudness while still sounding good is probably what you're after, and the ZX's will do the job just fine. IMO, with subs, you can't tell much of a difference, if any, when trying to compare the sq of different amps that are of at least good quality.
so u think cvx are bad? like i said i havent bought new subs in like 7 years or so, and as far as i remember all the top end shops sold jl kicker rockford and memphis then, i just heard of arc today
Like to know how that's possible. The Class G and Class H are both theoretically hybrid designs. Class G uses a stepped power supply rail voltage meant to supply slightly more voltage than the outputs need to effectively increase the efficiency of the Class A/B output devices. The Class H does essentially the same thing but with a smooth variable rail voltage, essentially a Class D amp feeding a Class A/B output stage. The idea of both is the fidelity of a Class A/B amp with nearly the efficiency of a Class D. I guess they can call it whatever they want.
mal1980
mal1980
indianapolis
helotaxi
