arc amp is being a *****
Id change the fuses out, even if they look good to you.First thing Id do.By the wire grounding out like that, a fuse should have blown, and should have worked for you.Tis is another reason why I recommend, and use a dist fused block at the amps.Its cheap, and can save your amp, and just an extra precaution.
true. i dont have it fused pass the battery. ill make sure to add a fuse dirctly on the arc. i'll also check the fuses, i assumed that since amp still powers up, that they are good. but when this happened it also burnt something out inside cus the rear inputs no longer work (its a full range)
Sounds nasty man.Might be a repair on the amp within the near future.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
haha that doesnt console me. luckily this was the first amp ive ever bought from an authorized dealer, called him up and he said if there was something wrong with ti, theyd replace it. but just wish this wouldnt have happened at all. plus im out of town for winter break, so wont have sound until early next year. =(
I hear ya..Talk is CHEAP These days with money already spent.//content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
hah, very true. this guy seems very cool and hes a respectable shop. so should go well hopefully. hes actually had a ton of his work featured on car audio and electronics magazine.
robertoyoung08
robertoyoung08
bay area, ca
robertoyoung08
