AQ2200D stuck in PROTECTION
Do some simple troubleshooting first.
Check the voltage at the amp to make sure that's good. Unhook the subs and make sure they are ok.
From there, try turning the amp on without the subs hooked up to see if that does anything.
And definitely, DEFINITELY turn off the bass boost. You also need to properly set the gain.
Do these things before calling AQ.
If all else fails, you aren't too far from me. We could possibly meet up and help diagnose your problem.
You had a 300a fuse on an amp that requires a 200a fuse. //content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
fozzy2134
fozzy2134
crown point IN
nicker10
