AQ2200D or DB Drive A7 2500.1
the db drive is a better amp and should last just fine they put out rated and then a little more. local shops two 3500s are clamping around 8900 at 1.2ohm, (.5ohm per amp) i dont remember the exact number but he's a local usaci competitor and makes finals just about every year. he abuses the hell out of his amps but he does have the electrical to back his amps as well
just the name db drive makes me feel leary..
yea when i first saw my local guys truck i thought it would just be meh and it was like every other mainstream sponsored car but the guy who designed it went a step above and it pressures a 157.6 which is pretty good for mainstream. plus i know at finals last year he pulled steady demos for about 3 hours and the amps held up to the constantly dropping batt voltage.
he did say though for a daily driver it would be better to strap two amp that have one bigger one when it came to db drive. something about efficiency and the amp holding up better. he said that was why he swapped his a7 7500 for the a7 3500L's.
oh okay, thanks.. Seems like db drive will be a better amp then from all the posts so far.
my .02.. id strap 2 aq 2200s, SS dtr 2200, even 2 ap 1.5ks before id run the db. its just that vibe i get. it very well could be a good amp..but not what i would do.
cresendo makes a mean amp..
fosgate does as well, although its mainstream.
my .02.. id strap 2 aq 2200s, SS dtr 2200, even 2 ap 1.5ks before id run the db. its just that vibe i get. it very well could be a good amp..but not what i would do.cresendo makes a mean amp..
you can't give advice on a feeling u get from a company bro...
like I said--- their very comparable amps... if you give either of the proper electrical, they will both put out very clean power. I don't have any experience with DB's current line up... but have had good experiences with them in the past. and I run aq now, and love them
completely based off of my opinion. when i can walk around walmart and see the db drive name, i assume for the worst.
its the same way some people go about audiopipe and hifonics.
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
Dirtrider4eva
