Long story short, I was running a hifonics colossus on my 2 Sundown sa12's for around 3 weeks and last weekend, a couple of the MOSFETs fried so its getting repaired.
I had an aq2200 on hand that's going in my second car soon, so I installed it so I could still have some bass while the hifonics was getting repaired.
I set the gains using the tweeter method outlined here:
http://www.caraudio.com/forums/amplifiers/614880-poor-mans-oscope-setting-gains-questionable-sub-amps.html
I'm currently running on my stock deck (waiting on a wiring harness) with an loc-1 line out converter with the output on that set to 3/4 up. When setting the gain on the AQ, I barely got past a quarter of the way up before the tweeter started buzzing loudly on the test tone.
Once I had the gains set, I took off for a test run. I was severely disappointed. While the hifonics is supposedly 1,000 watts more output RMS, the audioque wasn't flexing anything. Even my mirror was barely moving, and that thing used to bounce all over the place even on my old alpine mrv m850 and 2 type R's
So to experiment, I pulled out the aq2200 and stuck in my old elemental designs nine.1. I perceived this amp at a bit louder, but it still wasn't flexing anything in the car, and these are known to do 1400-1500 watts at 1 ohm and good voltage.
I never used the tweeter on the hifonics because I wljust went by the built in clipping light on the amp, and the gain was set to just under 3/4 of the way all the way up.
So is my tweeter method faulty, or am I just expecting a lot more than I should from amps that are well known to be liud?
