AQ2200 early clipping?
So, the loc could be sending a clip signal if turned up too far?
I'd say the stock head unit is sending a pretty dirty signal. The LOC just amplifies that signal, nothing gets cleaned up So basically you were getting a dirty signal from the get go. Probably the Reason why your hifonics blew in the first place.
ALSO
what DB test tone were you using? If you are using a 0 DB test tone, it could be why you are clipping prematurely too because your music might not even get close to 0 db. Most rock, mainstream and oldies rap are like -6 to -12 db
Here's how to determine what db test tone you should use along with how to generate such test tone
leave on annotations
ALSO
Thanks for all the excellent info man. So basically the problem lies solely in the stock deck. My wiring harness will be here early next week and I have a mid 2000's pioneer or alpine deck to choose from on hand to install for now, so hopefully that solves the problem
As for the rest tone, I did use a 0db tone at first but after I set the gain the output from the amp was pathetic so I reset the gain using a few different songs I normally listen to. Definitely improved but still not where I know it should be.
Badseed
Badseed
Erie Pa
basswiigee
