AQ not putting out...
You should get it drunk. Maybe then it will put out.
Nah, he should pretend that he is out of gas in the middle of nowhere and say "Put out or get out":laugh:
ETA: No offense to Audio Que, but you have to admit... that amp is NOT the proper choice for 4 ohm power in the OP's case! A pair of RE SE 12s will barely move off of its 4 ohm output!
play with the subsonic filter. mine wasnt makin any noise before i adjusted it.
i hooked it up and my subs were in a ported box and the amp came at 10hz on the subsonic filter. so i fixed that, and wow.
Gotta love that customer service!
I know, AQ has some very nice CS. When i ordered my amp i put the wrong mailing address in there. I called them the next day and they were very cool about it and switched it before it got shipped.
1. Rewire to 1 ohm (most everything else in this thread is pointless to do until you do this)
2. THEN Reset your gain (make sure your remote is set 3/4 way up)
3. Set your filters last, a good starting point should be ~80hz on the LPF, and ~1/3 octave below port tunning (probably turn it down more after testing)
Also this amp does not have a bass boost. You might have it confused with the bass/gain level.
Let us know how it turns out, should be a sweet setup.
After dropping the subs down to 1ohm, and talking with DJ for a few mins to help me with my settings, this thing pounds! I am a very happy customer and will recommend AQ to anyone that is looking for a very nice product with killer CS.
mythyone
mythyone
Greenbay, WI
sundownz
