AQ not putting out...
I would really suggest you go with the advice in this thread, esp about wiring your sub amp to 1 ohm. At 4 ohm, that amp only puts out 510w according to AQ website.
I am , gotta eat some lunch then im gonna go take another look at my amp settings, rca's and drop it to 1 ohm. Ill write back later with the results.
are the subs broken in yet? Maybe a weak ground somewhere, or a loose fuse holder? Check the integrity of the electrical system before judging the amp.
:rolleyes:that wouldnt be anywhere near the right answer. to say ure shits not hitting cus the subs are not "broken in" is dumb
? your saying this not a good amp, i know its not top of the line but i thought AQ had some good stuff.
Actually you get more then you pay for. Wired at 4 ohm you are only getting 510 watts. Wire the subs to 1 ohm and set your filters correctly. If you are using the remote Gain/Bass you might not have that set correct. Give me a call and I will walk you through the install.
Will do , thanks!
Great guy here BTW I just talked to him today and now im an owner of the AQ 1200d
//content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif now thats customer service right there
mythyone
mythyone
Greenbay, WI
sundownz
