Yea, you missed it. It's designed to be a loud azz daily driver sub. SQL is the often referred to term. MTX RFL= SPL sub... HDC3= Loud Daily subMaybe I missed something, but I'm pretty sure the HDC3 15 was built around getting loud.
sealed boxes can get very loud. The reason you want a ported over sealed for that sub is due to the ebp of the driver which is the fs divided by the qes. If that number is closer to 50 that sub is better suited for sealed and if its closer to 100 vented is the way to go(there are exceptions). Now any sub can play in any box. A sealed box is not optimal for the hdc3 but will work none the less. Most guys here want the most from their subs so they go ported however i'm very confident that your friend will be happy with that sub in that sealed box off 900 watts. Hell i've heard L7's(which most recommend ported boxes) in a sealed box and the sub moved a lot of air. Sell her the sub, hook everything up for her and she'll be fine. Are there better subs for her amp and space requirements, for sure. Will the hdc3 put out enough bass for a first system off 900 watts, i say hell yeah. Don't hesitate, hook the girl up.so people cant get loud in sealed boxes? im just trying to understand why it wont work in a low power sealed application...if the answer is just completely no then ill have to rebuild the car to allow for more space or something
In my experiance with the 2 subs my HDC3>RFL in SPL.Yea, you missed it. It's designed to be a loud azz daily driver sub. SQL is the often referred to term. MTX RFL= SPL sub... HDC3= Loud Daily sub
Terra, I would try it out in your personal car first, just to avoid any problems and to verify that it will work before letting her turn loose on the volume knob.
annnnd that is the answer ive been looking for. not necessarily because it gives me the go ahead but because he actually has reasons to support his opinion. thanks..sealed boxes can get very loud. The reason you want a ported over sealed for that sub is due to the ebp of the driver which is the fs divided by the qes. If that number is closer to 50 that sub is better suited for sealed and if its closer to 100 vented is the way to go(there are exceptions). Now any sub can play in any box. A sealed box is not optimal for the hdc3 but will work none the less. Most guys here want the most from their subs so they go ported however i'm very confident that your friend will be happy with that sub in that sealed box off 900 watts. Hell i've heard L7's(which most recommend ported boxes) in a sealed box and the sub moved a lot of air. Sell her the sub, hook everything up for her and she'll be fine. Are there better subs for her amp and space requirements, for sure. Will the hdc3 put out enough bass for a first system off 900 watts, i say hell yeah. Don't hesitate, hook the girl up.
I see a sundown 1500 in your sig, how much power did you have on your btl?In my experiance with the 2 subs my HDC3>RFL in SPL. No its not completly a one note wonder but my BTL sounded alot better. Yea its aimed for daily use but is is an SPL based driver.
Excellent suggestion!Look at a 15" SSD from Fi...should work great in 3 cubes sealed, and work well off of 900 watts as well.
