i will take you back to preschool man... who cares about SQ, not you.. i used to love output sure it was fun, but there is a time when one adheres to music not a fart box..
once you understand acoustics and transducers and how competition works its not really fun, just expensive..
you understand how much more difficult it is to get 150 on music with a faily flat FR while sounding sweet? lets just say its alot harder than simply matching the ports peak to the vechicals res, avoiding cancallation at the dash and getting alot of power to the woofer hoping not to kill the woofer..
those woofer handle so much power because, inductance fluxuation, impedence rise, power compression along with a very non linear motor and suspension(actually helps raise efficiency of the system)... aka thats why the big SPL woofers don't start to gain untill you pour more and more power.. in realitly a very efficiency highly linear woofer is better(this is preety much hwat hte 99z is but with a huge coil and sicking motor strength, wonder why they use a alum 3" coil?)... hence many companies are straying from previous spider surround designs..
no offense to dj cause the woofers are good, but your just not understanding whats happening or why..
drop a PA driver with a fair amount of xmax (15mm or so) and a stiff suspension along with a 981w1m efficiency.. now cut power by 1/4 and i bet you do similar numbers... in fact look onto acoustice elegance woofers... for the street classes in a hatch back they will do EXCELLENT in SPL, so will the AE AVs althought htey have a lower eficiency 1kw to them is around the same output as the 9500 with 2k....
btw i tested so many drivers if you cna give ACCURATE parameters i can tell you which woofer will be ideal for you installation, save ya alot of money... i mean dumax t/s parameters kms curves b/l curves power compression etc... i stopped using bass box pro a long time ago, very flawed when tring to prodict real world performance...
