Aq 1200
DocisChief
AQ 1200D amp (no bass remote/wire)
Original owner of amp, and have had it about three years. Never had to be serviced, no fuses blown, not abused. 9.9/10 cosmetically, there are some very small scratches around screw holes and on one very small portion of a corner. 10/10 mechanically. The only reason I'm selling is because I'm getting rid of the car that it was in, along with everything else I had in it. I'm hoping to save this money and put it towards another amp in the future when I get a different car and setup.
$200 shipped
I'm open to local pickups as well. I'm in the south suburbs of Chicago for those in the area interested.
View attachment 26536748View attachment 26536750View attachment 26536751View attachment 26536752View attachment 26536749
SQ series amplifiers are fully stable down to one ohm.
Daisy Chain connection of two amplifiers stable down to 2 ohms
Four way protection circuits: Speaker shorts, DC offset, High/Low voltage, Thermal protection
Double sided boards with high current MOSFET switching devices
24db/oct slope crossovers, Fully adjustable Low Pass Filter and Subsonic Filter
Remote Gain Knob Included
Specifications
Model AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,870X1 @ 2 ohm,1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dimensions 12.75"(L)x9.27"(W)x2.35"(H)
DocisChief
DocisChief
Illinois
knotdrummer88
