Anyone Try These HUs?
More power to a set of speakers without the need for an external amp. That is if it does the claimed power and a normal voltage. Common sense really.
so is knowing that a headunit wont put out anywhere near 75 watts!
Consider me schooled. I will be junking my 60x4 Eclipse amp and buying that head unit instead because 75 is a bigger number than 60. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Hell I bet I could get rid of my sub amp too. Bridging that head unit's two rear channels probably=150 watts. I could run a set of comps off the front two channels and maybe one 8 off the rear two channels.
If you can't find the rms numbers published anywhere it's a good sign that they're pretty low, ALOT lower than the peak. Most quality aftermarket HUs advertise 45-50 watts peak but will actually make 15-18 rms, just to give you a general reference point. Your HU advertises 75 max so you may well be getting as much as 19 or 20 watts rms. Should equal 20 extra dbs.
Ninja Primate
Ninja Primate
Behind You?
dumple
