Anyone try the digital fuse holders?
well either way I was wondering if the technology was there. Like if they are able to be realistic along with how they work as in when the led's turn on and off
meh, pretty much useless while your driving....
what you need to get is a volt meter from ebay, I got mine for 00.99$ from a chinamen....shipped in about 8 days
I mounted it right on my dash, and I have it hooked on a up reading right of my sub amp in the trunk. now I can see when my volts drop below 13 and turn it down, best 99 cents i spent
I have it on a relay so when I turn on the ignition it turns on as well
well I have 2 amps, 4 fans, and the volt meter running of a dual relay ran from my ignition power wire. the remote turn on barley puts out any output.
either way your going to need to use a relay.
relays can be found at most electronics stores, auto shops....
12V 30 Amp 5 Pin Relay SPCO 30A £1.99 - in-car-stuff.com - Car Alarms & Security, Car Audio, In Car DVD, In Car TV, Speakers, Subwoofers, UK and Ireland delivery
no you have to use the remote to switch on the relay, its hard to explain, I can draw you a diagram tomorrow im to tired
basically you need to have it hooked up so that the + of the volt meter is hooked up with the power at your amp, or on the + battery terminal, and the negative wire from the volt meter to the relay so when you turn your car on it conducts the ground and completes the circuit. so instead of having power when the relay is switched on, you have a ground when it gets switched on
ugh im beat...hit you up tomorrow man
bunkrd you
bunkrd you
papillion, ne
FenixAudio
