Anyone know where to find pictures or how to install speakers!!!
Get the right wiring and fusing you need before doing your final connections and mounting of the amp. If you have the amp connected with the improper wiring or no fuses you could damage it.
Or if it was done carefully he could do nothing at all but enjoy it!
The concept of fused power cables for amplifiers is highly overrated IMO...
how easy is it to blow 6x9s?
I would suggest about as easy as blowing any other size driver if you abuse it.
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
I don't know how many various amps I have installed in different cars I have owned....in cars belonging to friends that I was helping them get their tunes lines out....blah, blah, blah...
I know what the conventional wisdom on the subject is. I am well aware of the quite sound reasons most people think this is an absolute imperative bit of installation. I don't. Not once since I got into aftermarket mobile audio have I ever had reason to eat my words...up to and including when an ex of mine borrowed an '83 D250 P/U I had once....while she was out she left my fog lights turned on and killed the battery while she was shopping. She didn't pay attention to what she was doing when she got a jumpstart from someone and hooked the cables up backwards. ( ) Every single fuse in the truck's fusebox blew. The fuses in the sides of my amps blew (yanno - the ones that almost every amp has stuck in the side of it somewhere) The fuse that was inline on the power cable for my EQ blew as well as the one in the back of my stereo. After replacing this double handful of fuses in various sizes and types everything worked fine. *shrug*
Like I said - from personal experience all that external fusing is an overrated concept IMO.
when i get subs this summer.. i will need a much larger amp(S) but i have my a6004t runnin my 6x9 n 5.25.. what will i have to do.. or is that no a problem.
You'll just install the necessary accessories to run a multiple amp setup. I think almost everyone here is running more than one amplifier. There are those that aren't but I think they are in the minority.
The easiest way is to have a run of large cable (4awg or bigger dependant on your particular needs) from the battery and into a distribution block. Out of the other side of the distro will feed the smaller cables that supply the amps.
//content.invisioncic.com/y282845/emoticons/iagree.gif.15d6c075ee8d3913ba26866d06993068.gif
shanerz21
shanerz21
IOWA
revrider1
