Anyone know this speaker from the 90's ?
blaze_01
Anyone know what speakers these are?
The Brand are "Canton" they are 8" (inch)
I cant confirm if they are fulltone or mid bass, but they certainly plays pretty high
in frequencies..
I was looking for specs on these.
Canton Pullman w 22.20 ... maybe from Canton Pullman RS5 3 way set ? .... found this also ..
data of woofers canton pullman w 22:20 Product Description · Rigid lightweight paper cone Treated foam surround · · bumped and vented magnet Pole Piece · heavy Duty Steel stamped basket Specifications: · Power capacity: 120W / 240W RMS / peak Product Description · Rigid lightweight paper cone Treated foam surround · · bumped and vented magnet Pole Piece · Heavy Duty Steel stamped basket Specifications: · Power capacity: 120W / 240W RMS / peak · Frequency Response code: 25Hz ~ 1KHz · Nominal impedance: 4? · Voice Coil Diameter: 2 " · Magnet weight: 47oz. · Sensitivity: 87dB W / M · Fs: 25.7Hz · Re: 3.4? · Le: 2:47 mH · Qms: 14.0 · QES: 12:22 a.m. · Qts: twelve twenty-two · Vas: 30.43 liters · Mms: 59.78g · Xmax: eight mm (one-way) · Magnet gap height: 8 millimeters · BL: 12.99 · Piston Diameter: 163 mm Dimensions: · Overall Frame Diameter: 08/25 " · Required cutout: 7.125 "Diameter · Mounting Depth: 4.5 " · Frequency Response code: 25Hz ~ 1KHz · Nominal impedance: 4?
Wo thanks alot:) im suprised someone knew it, i asked alot of enthusiasts and they never heard about the brand.
So basically the specs are:
Power capacity: 120Wrms 240Wpeak @ 4 ohm?
So its quite good speakers, pretty decent? but they belong to a component set? or separate woffers?
The amp on these only does 90wrms @ 4 ohm.
I still think these speakers is alright. but they mess a bit with the soundquality as i have a component set of ground zero at front.
blaze_01
blaze_01
Norway
Ironsave
