anyone know how to?
ok thx for the help but i didnt understand any of it. ok the amp is BOSS rev555 700X2ch(max) 125X2ch(rms) the subs i was looking at are three of the Rockford fosgate 3810, i think they like 200watt(rms) 400(max). and i was wondering if there was a way if i out them all in a box if i could rig them all up to my amp?
Brand New Rockford Fosgate RFP3810 Punch Z serie Subwoofer Description Size 10 inch Type Woofer Voice coil Configuration - Single Material - Aluminum Description - 2.5" 4-Layer Cone Material Paper - FIBERlock Frame Material Frame - Stamped Material - Steel Surround Material Foam Description - BART Crossover Specifications Power handling(RMS) - 200 Watts Power handling(Peak) - 400 Watts Impedance - 8 Ohms Sensitivity - 85.7 db Vas - .507 Fs - 34 Qts - .507 Xmax - .51 Dimensions Depth Bottom mount - 5.375 in. Cutout - 9.3125 in. Displacement - 103.68 cu in. Enclosure Sealed box - Recommended Minimum Volume (Cubic Feet) - .625 Recommended Maximum Volume (Cubic Feet) - 1.5 Ported box - Recommended Volume (Cubic feet) - 1.0 F3(Hz) - 35 Number of Ports - 1 Port diameter(Inches) - 3 Port Length(Inches) - 13.25
that a discription i new at this so im no exactly sure what everything is. thx for the help
the only way i could think of 2 subs w/ a non-bridgable 2 chanel amp is to hook each channel to 3 voice coils, but thats with DVC subs. I'm to tired to think man, ill think about it and someone else might know something, and im just being dumb...
dat amp wont be enough for 3 subs. maybe 2 subs, but i dont' even know if that boss amp actually pushes what's rated at. check out at gettin a new amp
its possible...but it mostly depends on the subs and what the amp can handle. if it can go down to 1 ohm, and you get 3...say...jl 13w7s..you can wire those three subs up to a 1 ohm load since they are 3 ohm svc.
i doubt that amp will go at 1ohm for more than half a sec, lets see if it claims 700 watt maxx then your prolly gettin 200w rms, so i would just hook up 2 and give em 100 watts each
davidfre21
Is just a lil racist...
davidfre21
WesTex
DaBaller504
