Anyone bored enough to quickly 3d design?
JeepSound
vtec-lol
Finally ready to build the box for my single cab Ram.
It's a truck style box with a...
13.5" bottom depth
10" top depth
20" height
24.5" width
It'll be for (2) 12" Soundstream Rubicons with around a 7" mounting depth.
Tuned to somewhere in the 34hz range if possible.
Basically I'll need two of the above boxes sharing the same back board with a 16" gap in the middle used to hold the amp. So it'll end up looking like this, only less shitty...
So if anyones bored, I could really use a 3D design with dimensions //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That is a very small space...I wouldnt do it, unless that space is for each sub's enclosure..
Came out to a little over 2 cubes each according to the calculator I used...
This is with 1/2" MDF as well so that'll make a slight difference.
EDIT: I think I see what you're getting at... The dimensions I listed will be the chamber for each sub, if thats what you're asking.
JeepSound
vtec-lol
JeepSound
B.C,Canada
JeepSound
