any suggestion on a new system??
UpNCommin
allright.. heres the plan... i wanna throw 4 12's (why? cause it looks better for show n i like how 12s sound more clean than 15s but deeper than 10's) i have 2 amps that i could use ... either a soundstream 2000w rms @1ohm OR a ppi 1600w rms @4 ohms bridged or 800w X2 @ 2ohms... well the thing is i still cant decide on 4 woofers that i can power with that.. i'll do 3 woofers not 2 tho.... any suggestions??????? any help IS GREATLY appreciated...
Good luck wiring 4 of them to one ohm.
Ya but how many dual coils are you gonna find to power with 2000 watt amp?
theres plenty out there //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif 500 watts per woofer there are plenty of drivers out there that would be perfect for his setup
what type of car?
am good w/the soundsteam.. lol its juss that i kno ama have to get sum subs like sum CVR's or sum MA 120xe's but i want somethin different...everyone has those in el paso ... so any suggetstions??
i'd use the ss 2000 @ 1 ohm
get 4x dvc 2 ohm subs, wire each sub in series then parallel them all
just be sure you give each sub its own chamber, i'd go sealed with probably some ascendants
yeah i was thinkin on makin 2 chambers... 1 chamber for 2 woofers... i dunno if it would be right to give one of the chambers a port juss for extra kick but i dunno... lol... well what subs do u suggest/???
UpNCommin
UpNCommin
Austin, TX
mlstrass
michigan born
    May 14, 2026
michigan born
    May 14, 2026
