Any point to using the HU's Low Pass Filter...?
The only thing holding you back is preference. Try the HU's crossover and see if you like it better. Try both together and see if you like that. Experiment and find out what you like best.
I'm constantly thinking "If I raised/lower the frequency to both the fronts and subs 5hz...". It would make a HU with active crossovers a godsend, but I can't afford that kind of thing.
Wouldn't, in theory, using both crossovers strengthen/raise the DB slope? I'm not exactly sure how crossovers work COMPLETELY, but say the HU has a 6 db slope and the amp has a 12 db slope, would they combine to create a 18 db slope? Just tryin to learn.
OK, this is my personal opinion on the issue.
How in the heck can you trust an analog pot to xover your subs at the exact frequency desired?
Answer: You can't.
Real solution, use the LPF on the HU for ACCURATE LPF. This way, you know the exact xover frequency, as opposed to GUESSING with an analog pot on the side of the amp. JMHO, but it's a solid hypothesis lol.
Answer: You can't.
Good point.
Thats always bugged me alittle, I wish amp manufacturers would put good accurate crossover with an adjustable slope from 12 to 24 db, I know a couple companys do on a few models I just wish it was more universal.
Good point.Thats always bugged me alittle, I wish amp manufacturers would put good accurate crossover with an adjustable slope from 12 to 24 db, I know a couple companys do on a few models I just wish it was more universal.
I could do it on my kicker sx 1250.1 actualy was able to do way too much stuff.
Yes, that's how it works.
Answer: You can't.
i have digital crossovers.
Answer: You can't.
Thats what I was thinking as well. My RF T10001BD is a great amp, but the xover is quite difficult to accurately set. I thought I had the amp crossed exactly @ 80, but when I adjusted the HU to 80 as well just for fun, there was indeed more bass (indicating I was somewhat off on my guess). I think I'll set the amp wide open and run the HU's xover.
Combining a 6db slope and 12db slope wouldn't automatically create an 18db slope (the final slope depends on a lot of different factors).....but yes, they would "combine" and increase the slope of the crossover.
Answer: You can't.
To the contrary......the exact frequency you are crossing over at doesn't really matter...at all. What does matter, is how the system sounds with the crossover set to where you have it set. Does it matter if it's 68hz or 82hz or 50hz? No, not at all. And due to most amplifiers having a continuously variable frequency (you can set it anywhere within a range...say 35hz to 200hz), and most HU's have very limited, specific frequencies you can select (most are around 50hz, 63hz and 80hz, and you can ONLY set to those specific frequencies), using the amplifiers crossover gives you far more adjustability in selecting the setting that SOUNDS best without being overly restricted to what frequencies you can select.
My hypothesis is more solid //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Mr. Black
Mr. Black
Alberta, Canada
squeak9798
