I finally got my two AQ 1200D's and plan on wiring everything up tomorrow. The two BL's are dual 2's. Should I strap them together or just run each sub to each amp?
If I do strap them, I just go from the positives on master amp to the each positive on the terminal for the subs and the positives on the slave amp to the each negative on the terminal, and then just connect the negatives from both the master and slave amps correct?
The only benefit of strapping would be that I could just use one bass knob and the gains and settings would just be ran off the master amp right?
