Any chance to fit 3 12's w/ only 36" wide?
If ported i want a box to have the port blowing into the cab(up). But i would still need to have my beauty panel there so it cant come out more then 20" from the back.
I would say I'm cheap if you want to go that way(cheaper then buying the tools that is for sure). I didn't crunch the numbers you posted yet, but I don't see why it would be to hard or that large of an enclosure.
If you want check out some of the box build threads I have done in the build section. I would be more then happy to help you out.
I'll check em out. I'd prob just go w/ dual chamber center port.. It would prob be more cost effective to just build a new box then to buy another sub and a custom staggered box.. Will the output be similiar? The only ported box i had were w/ some 12" l7's back in the day w/ a 1501d and it sounded like dooky.
And if i went ported i could do it myself. I'd just need measurments..I **** at the maths.
I would say it would very close... however you are talking about dropping the ohm load and adding cone area so it would close. I will check the specs and you available size when I get to a computer in a few.
Definitely need to stagger them, heres a 3 12 sealed build I did a little bit ago, box measures 36wide 24deep 13high and after sub and bracing displacements is 4.75 cu/ft:
heres the inside:
I thought you guys meant sumtin diff by staggered..I can't have my box that big cause i want to retain my trunk and Beauty panel.
thanks. ima go double check my measurments really quick
Sleeklsc
Sleeklsc
pro-rabbit
