another whats a good amp to buy on a budget....
freakin_rican
i am looking for a amp to buy under $300 for a pair of ALPINE TYPE R's 12's(1243D) in a ported box...it will be hooked up through the factory radio and i will use a ipod touch also any suggestions will be appreciated this set up will be used daily and pushed hard so a dependable amp will be needed thanks!!!!!!!
Audiopipe does rated without clipping! Power is power, all amps are the same! Don't let those "ess que" companies lie to you, amps are amps and they amp the same! Those companies selling amps at over $1k each are all just scammers!
How have they stayed open for decades, you ask? Well, isn't it obvious? There are just sooo many people out there looking to spend $1k on amps that do the same power as those $100 amps. There's no difference in them at all.
Dude buy a HU. You are not going to like going through the stock. It *****! Even a cheap POS HU is better than running through a stock radio.
That's not true. I'm usin stock head unit in my 2008 accord with the audio control lc2i. It's perfectly fine and sounds great.
And what about the new hifonics brz1700.1?? I also have the same subwoofers as you and I'm wondering what's the best budget amp.
freakin_rican
freakin_rican
whitehall michigan
freakin_rican
