another question
See Pic Below...
from audiobahn's website
Q: On my Q series sub, why are there 2 + and 2 - terminals on each voice coil?
A: There are 2 + and 2 - on each voice coil. This is so when wiring the subs together you do not need to try and fit both wires in the same hole. You do not have to use both on each coil, but it will let you use a larger wire. Think of them as Y connectors. Both + and both - go to the same place on the same coil. You can wire as normal and only use 1 + and 1- on each coil.
Iceteebone so if i understand correctly, i can run them like this and use one pair of the push ins on each side, i do not have to use the other set??
from what i gather from audiobahn's website, is that it is for ease of use. so basically positive from amp to one terminal, then on the same side the other terminal on the same side to the other side. i'll draw something up in paint if you want.
cooper1513
cooper1513
ny
cooper1513
