Another noobie question
You can run a single voice coil sub on two amps. What sub, amps, and why do you want to use two amps?
DD 9515, 2 Alpine mrp m1000's, and well, I have an 4 channel V power amp aswell. I know i can stack the amps so i thought it would be a good idea. Think i should not?
So is your sub dual 2 ohm? If so you could run an amp per voice coil but you would have to line match the amps as already stated. You would do this by setting the gains the exact same on each amp with a digital multimeter. I set my gains by ear and never have had to line match so someone else would have to explain how or you could research setting gain with DMM yourself.
Yeah its a dvc. You think ill be good then?
Lol, did you even read his reply?
You'll need a DMM in order to set the gains at the same setting. If you have one, fantastic - get them line matched. If not, I'd recommend a single amplifier.
SBFandy
SBFandy
Wisconsin
robert420
