Another Help Question
always hook up positve first, but make sure there is no fuse in the power wire. so just hooke up the positves (without fuse), then negatives, and then remote, and then put in fuse.
How do I hook up positive first (without fuse) if my power cable has the fuse on it?
Do you mean plug the positive into the amp first, then negative, then remote, and then put the power on the battery? My cousin always does the front, and I do the back when we run amp wires.
How do I hook up positive first (without fuse) if my power cable has the fuse on it?Do you mean plug the positive into the amp first, then negative, then remote, and then put the power on the battery? My cousin always does the front, and I do the back when we run amp wires.
Take the fuse out of the power cable until all other connections are made and secured.
THEN put the fuse back. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
take out the fuse in your power wire(s). Connect the power wire to the battery then to the amp. Connect the ground to the battery then to the amp. Run the remote from the HU to the amp. Connect the amp to the subs. then install the fuse in your power wire(s).
fwb_1234
fwb_1234
Greenville, SC
spin dB
vegang
vegang
