Another box for my sa-8 v3's
inteva6184
pa
Hey guys I Just got my seat lift kit in so I can make another box for my 2 sa8 v3's. I took the advice from cscstang and I ended up with 1.48 cubes with a 4" aero tuned to 35hz. Only thing is the box was oddly shaped to fit the area I had. The box sounds good and hits low I just kind of expected a little more out of them. Ive seen plenty of videos of them doing work in peoples vehicles and while I am not dissapointed I am not real impressed either. So my next box will be more of a traditional wedge shape under my seat and I can make it around 1.8 before sub or port displacement. So the question is do I follow the same formula I had or is there anything I can do to get more out of the subs. More port area, different tuning or box size? I dont think power is the answer on a clean signal they already get pretty warm after some good abuse.
For reference this is the oddly shaped box that may or may not be hurting output.
"][/url]
Where's the port loading off of and how far? Yeah those 2 8s do put out quite a bit but in a larger cabin they won't be crazy impressive.
Sent from my SM-N920V using Tapatalk
From the drivers side door the port is about a foot. When you say flip sub placement do you just mean mount them at opposite corners?
Correct on sub placement and is it possible to move that box 6-8" from the driver door? You'll see a difference in output.
What is the reasoning for putting the port close to the door? Also is there a point where it can be to close?
inteva6184
inteva6184
pa
Austin175
