Another Battery Question
Crownvicon28s
God 1st
I plan on getting rid of my redtop upfront because I will have an AGM battery in the back because mixing different kinds of batteries shortens the lifespan of the batteries right? With that being the case does it matter which AGM battery I put under the hood because I cant fit a battery like this under the hood, will any AGM battery work? I was thinking a Kinetik 1800.
I just ordered an XS Power D3400 that is said to be much stronger than a kinetik2400. It's replacing my factory battery under my hood and that's the only battery I'm going to run. I have no room in the back for another.
From Here
http://mechman.com/store/index.php/cPath/1
I plan on getting rid of my redtop upfront because I will have an AGM battery in the back because mixing different kinds of batteries shortens the lifespan of the batteries right? With that being the case does it matter which AGM battery I put under the hood because I cant fit a battery like this under the hood' date=' will any AGM battery work? I was thinking a Kinetik 1800.[/quote']
you want the batteries to be as "alike" as possible. By being as alike as possible you want them to have the same resistance and capacity that way they charge and discharge closer to the same rate.
The red top is an agm battery just not a deep cycle.
Also is that d3400 more powerful than a d2700? I know its smaller and cheaper than a d2700 and a good buddy of mine just sold his d2700 because it was his weakest battery.
you want the batteries to be as "alike" as possible. By being as alike as possible you want them to have the same resistance and capacity that way they charge and discharge closer to the same rate. The red top is an agm battery just not a deep cycle. Also is that d3400 more powerful than a d2700? I know its smaller and cheaper than a d2700 and a good buddy of mine just sold his d2700 because it was his weakest battery.
o ok. i didnt know that about the redtop. i still plan on gettng rid of it any way. i can get the hc1800 at a pretty good price so i think im going to go with it.
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
