Another bad Whining problem
  • 2
danny_isr
nyc,ny
I already did a search on this forum , and I know about the common answer grounding grounding ...
So I went and did that, but no success
The full story :
I have a Premier 860 running two brand new kenwoods amps(8401 and 6401) in the trunk .
Honda Civic Sedan LX 92
3 pairs of RCA’s and speakers wire on the right side of the car, power on the left.
I disconnected the RCA’s from the Amps and the noise disappeared. so my conclusion – it’s not the amps .
The amps have each one monster 8 gauge cable to the car chassis (both in the same point).
So I went and connected the black minus wire of the 860 to a different point – one of the car bolts.
And wired another 8 gauge wire from the deck body to the chassis (different point of the black 860 wire) – very solid.
Same thing, still got that whining. I actually can hear it even before I start the engine. I can hear I guess the ECU or something like that
When I turn the key on.
What should be the next step ? how can I determine if the noise is from the RCA’s or from the Deck itself ?
Another issue that I had during this install and I don’t know if it’s related or effecting anything here:
While I was pushing the deck back to it place. Suddenly everything died. I checked the 12V wire that feeding the deck.
And it showed only 1v. When the engine run I got 3.6v. Didn’t find any burned fuse. The clock of the car seems to be effected as well. And the LCD is very weak .
So I took another 8 gauge wire directly form the battery to the deck AND connected it to the old 12v wire (the one that shows only 1v) and then the clock came alive.
I did try to run the deck disconnected from that old 12v wire but it didn’t effect the whining .
Will appreciate any suggestions
Thanks Danny
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i hope its not the case.
but before i'm sending it back. i want to check that it's not the RCA cables
any easy way to do that ? i remembering reading somewhere about doing some kind of shorts on them ....?
any one recalls ?
Thanks Danny
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
586
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
883
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
danny_isr
danny_isr
nyc,ny
danny_isr
