another amp strapping question
I am strapping two sundown SAZ 3500s. I have two D2 woofers. here is where I am getting confused. I wired the woofers up to 4 ohm each. both positives go to the master and the negative to the positive inlets on the slave. with the sundown amp internally combining the two speaker inlets on their mono-blocks, is my final ohm load at 2 since the are being combined inside the amps?
Whatever load you would get on the ends of your leads that you're plugging in is the load the amp will read. If you have both subs at 4 ohms, and then have them in parallel, you would have a final 2 ohm load.
topdawg
topdawg
Killeen, TX
wew lad
