Another 8" sub thread
  • 6
gunz4me2
Bat Country
1,676
Louisiana
So here is my dilemma, I have a pair of Digital Designs 1508s, single 4 ohm, and I would rather have a 1 ohm nominal load than a 2 ohm nominal load. It looks as though it will cost me approximately $300 to have them re-coned in DVC configuration and I would rather not spend that much money just to end up with a 1 ohm nominal load.
So my question is, what other 8" subwoofers will work in 1 cubic foot net per sub tuned to 40 Hz and cost me less than $300 plus shipping?
I was looking at the Sound Qubed HDS2.108 and wondering if that would fit the bill? Also, any other suggestions on subs that will work in this enclosure with 1000 watts rms?
So instead of just buying an amp thatll give you 1k at 2 ohms youre going to buy completely new subs?
Whats wrong with 2 ohms?
So instead of just buying an amp thatll give you 1k at 2 ohms youre going to buy completely new subs?Whats wrong with 2 ohms?
Well, that would require that I scrap my MMATS HIFI-6150D which is running the whole system. Also, I alternate between a sealed 10 and my 8s depending on my mood. The sealed 10 is OK for SQ purposes, but I'd like to give my 8s more power and replacing the 8s would be cheaper than buying 5 channels of amplification.
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
479
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
861
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
gunz4me2
Bat Country
gunz4me2
Louisiana
gunz4me2
