Amps
Depends on the amp. If the current one connected has a preout you can just use that second amp but you won’t have receiver tuning capabilities to the speakers hooked up on it. If both amps are higher end and run 2/3/4 channel mode you can run half the rca’s And still get signal to all channels on each amp but you’ll still be missing receiver level tuning to the channels that aren’t rca direct to the the receiver. Most thorough option is to get a dsp. The Dayton one seems to have a strong value and benefit buzz.
I already have a sub and highs amp running through a clarion eq. I need to know how to get a music signal to the third amp. Is it ok to split the rca's between the 2 highs amps?
Yeah but just know what ever you split on those rca’s Will get the same frequencies. So if your split your highs on one set of rca’s Youll need to split your mids on the other set. A dsp is different than an eq.
383
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
the10man
the10man
Florida
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
