Amps worth fixing?
twentyinchburb
I had two broken amps given to me today, one is a power 800a2 that gets hot about 30 seconds after you power it up and it will hardly move a sub. The other is a punch 800a2 it keeps blowing fuses as soon as it's powered up with or without subs hooked to it, these are the older silver amps with the black end caps, are they even worth getting fixxed, and where can I send them to get fixed if they are worth it?
Contact the companies that make them and see what it would cost to repair them. Dont know much about those amps but when I need an amp repaired I found out how much I can get a working one for and how much it will be to repair it. If you can get another one cheaper than the cost of repair, then a repair is not worth it.
twentyinchburb
twentyinchburb
Iowa
JLJunkieMX107
