I know exactly how it works. Its typically pulsed DC created by a series of switching FETs run through a transformer. The fact is that the tranformer only works because of the pulsed nature of the current. It roughly approximates AC. If you hook straight DC up to a transformer, nothing happens except the transformer gets hot. As soon as you rectify the output of the transformer, it is no longer AC it is once a again straight DC. Both the input and the output of an amp power supply are DC. It is turned to AC by the output stage of the amp but that has nothing to do with the power supply. Pulsed DC through a transformer is the basis of an "unregulated" power supply. Because the switching frequency of the FETs is based on voltage, there is still some regulation of the power supply. This is the most simple of the basic amp supplies. Because there is a transformer involved, the output voltage of the transformer is a consant multiple of the input voltage.HUH?? chopped DC is used @ the input to an amps transformer.... form there it is rectified thru diodes and filtered, where we get ac voltage.
the power supply takes dc voltage and inverts it to ac voltage. it does this @ a certain frequency, with d class amps actually switching into the audible higher freq range. thats why they only work well as sub amps, because @ higher freqs you can actually hear the switching noise as the voltage is being chopped up.
I find that comment extremely funny considering the multitude of full range Class D amplifiers used in both car audio and home audio that sound just as "good" as any other class of amplifier.thats why they only work well as sub amps, because @ higher freqs you can actually hear the switching noise as the voltage is being chopped up.
DC transformer is a concept and realizations have existed at least back to the 1920s. basically it is a switching supply. if you fix the pulse width and frequency of a forward, bridge, or push-pull topology, the output voltage becomes a function of the input voltage (and the transformer). and the input current is based upon the load current and the transformer. functionally, it is a DC transformer.You should know well enough that there is no such thing as a DC transformer...
A transformer requires AC to work.
