Amps really hot
under 1 ohm i am thinking but you will get a reading.
maybe .02-.05 ohm depending on how much resistance is in the wire.
what you ocudl do to tell for sure is measure from amp ground to the bolt you have grounding that wire tot he frame. That will give you the maount of resistance in that piece of wire. Then meausre to another spot and that will give you the amount of resitance "through" the ground path.
I imagine if it was bare metal and it is connceted secure the ground shoudl be fine //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
PESteele
I wang on an 8 in a van
PESteele
annapolis
PESteele
